Now I have a doubt:
I have in FreeRTOSConfig.h
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 46 * 1024 ) )
And I have in the linker file stm32f767xx_flash.icf:
define symbol ICFEDIT_size_heap = 0x8000;
I guess FreeRTOS is using configTOTAL_HEAP_SIZE instead since it declares an array in heap4.c
PRIVILEGED_DATA static uint8_t ucHeap[ configTOTAL_HEAP_SIZE ];
So my attempt of increasing the Heap by changing the linker file from 0x200 to 0x8000 was pointless. This was not the problem…
The ping service is enabled and it works fine:
Pinging 192.168.0.10 with 32 bytes of data:
Reply from 192.168.0.10: bytes=32 time<1ms TTL=128
I have changed the Heap to 96Kbytes and it WORKS
But if I put it 128Kbytes it crashes…
So can I conclude that FreeRTOS does not use the heap declared in the linker file?
Can I put it back to 0x200, which is like not having a heap almost…
many thanks
