FreeRTOS hangs - iMX8 CM7 RPMSG
I tested this workaround (with rpmsg_queue_recv_nocopy() in my case) and It doesn’t work.
Calling with 0 timeout doesn’t fix the issue.
At the moment the only effective workaround is setting configUSE_16_BIT_TICKS to 1.
I let you know.
