freertos build error
bachadamin wrote on Tuesday, March 07, 2017:
Hello guys,
when I build my freertos stm32f0 project i found an error that says" padding struct to align ‘uxDummy10’ [-Werror=padded]"
rtel wrote on Tuesday, March 07, 2017:
Which version of FreeRTOS are you using?
Which compiler are you using?
Which file is the offending line in?
FreeRTOS v9
ARM GCC
FreeRTOS.h
I suspect you have configMAX_TASK_NAME_LEN set to a value that does not end on a 4 byte alignment, but even so the compiler should then adjust the allignment of the following members, which it is apparently doing. I don’t think that should be an error though, just normal behaviour, you have just set the compiler to tell you it is an error with -Werror=padded.
bachadamin wrote on Wednesday, March 08, 2017:
Now I have this problem
undefined reference to vTaskStartScheduler' undefined reference to xTaskCreate’
even if i included all the required headers !!!
rtel wrote on Wednesday, March 08, 2017:
Including the headers does not include the functions. Are you building
FreeRTOS/source/tasks.c?
