FreeRTOS and FastSerial
tarribas wrote on Monday, July 09, 2018:
I’m trying to compile a FreeRTOS implementation and I need FastSerial.h, but I receive this erro:
…\libraries\FreeRTOS\port.c.o (symbol from plugin): In function `pxPortInitialiseStack’:
(.text+0x0): multiple definition of `__vector_12’
Myapp19.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
c:/program files/windowsapps/arduinollc.arduinoide_1.8.10.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/…/lib/gcc/avr/4.9.2/…/…/…/…/avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
collect2.exe: error: ld returned 1 exit status
rtel wrote on Monday, July 09, 2018:
I’m afraid there is way too little information in your post to know how
to reply. I can glean from the file path that you are using an AVR GCC
port - which is not from us - so I would recommend asking whoever you
obtained the code from. As a guess it seems that you have the same
interrupt defined twice - once in the FreeRTOS port.c file, and once
elsewhere - maybe in example or driver code.
Sorry,
I’m using Arduino Mega environment.
With the FreeRtos sample I can reproduce the problem:
'# include <FastSerial.h>
'# include <Arduino_FreeRTOS.h>
// define two tasks for Blink & AnalogRead
void Task1( void *pvParameters );
void Task2( void *pvParameters );
// the setup function runs once when you press reset or power the board
void setup()
Sorry,
I’ve identified the problem, related with my ISR handling
Please close this issue.
heinbali01 wrote on Tuesday, July 10, 2018:
Maybe you can tell what caused the problem? It maybe useful for other users reading this post. Thanks.
