feanoriii wrote on Monday, April 07, 2014:
Hi! I’m trying to get Segger emWin working with FreeRTOS.
I’m building an user interface using the LCD and Touchscreen from the stm32f4-eval.
I would like to know if I’m correctly structuring my project.
In my interface there are 2 buttons, the first one creates a graph window in which I show the square wave of a led blinking (the led toggles within a TIM interrupt), the second one creates a graph too, in wich I show data coming from the IMU.
I create into the main function the first backgrund task, which creates the interface and, in turn, creates also other two tasks, adding values to the graphs.
My code works quite well, but 9 times out of 10 I can’t get the two graphs to be shown toghether (only one at time shows up) side by side. Sometime the project also gets stuck in “HardFault_Handler”.
I’d like to know if there is any problem with the structure of my project as I though it.
I paid attention to all the priority and stack problems with Cortex M4, and I think the code is ok from this point of view, but maybe I’m still missing something.
Flags are set and windows are created/deleted into callbacks in TestGuiBigDLG.c emWin file.
Thank you!
#define Background_Task_PRIO ( tskIDLE_PRIORITY + 10 ) #define Background_Task_STACK ( 512 ) #define Demo_Task_PRIO ( tskIDLE_PRIORITY + 9 ) #define Demo_Task_STACK ( 3048 ) #define Demo_Task_PRIO2 ( tskIDLE_PRIORITY + 8 ) #define Demo_Task_STACK2 ( 512 )xTaskHandle Task_Handle;
xTaskHandle Demo_Handle;
xTaskHandle Demo_Handle2;int main(void){
STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_GPIO);
STM_EVAL_LEDInit(LED3);
STM_EVAL_LEDInit(LED4);TIM_Config(); EnableTimerInterrupt(); IOE_Config();
Demo_GyroConfig();
Gyro_SimpleCalibration(Gyro1);/* Create demo task /
xTaskCreate(Background_Task1,
(signed char const)“BK_GND”,
Background_Task_STACK,
NULL,
Background_Task_PRIO,
&Task_Handle);/* Start the FreeRTOS scheduler */
vTaskStartScheduler();<span style="color: #008800; font-weight: bold">while</span>(<span style="color: #0000DD; font-weight: bold">1</span>){
}void TIM_Config(void)
TMD_STM32F4_TIMER_Init(TIM1, 5000-1, 16800-1);
TMD_STM32F4_TIMER_Start(TIM1);
TMD_STM32F4_TIMER_enableIT_Update(TIM1);
}void EnableTimerInterrupt()
{nvicStructure.NVIC_IRQChannel = TIM1_UP_TIM10_IRQn;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
nvicStructure.NVIC_IRQChannelPreemptionPriority = 15;
nvicStructure.NVIC_IRQChannelSubPriority = 0;
nvicStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&nvicStructure);
}static void Background_Task1(void * pvParameters)
LowLevel_Init();
GUI_Init();
GUI_SelectLayer(1);/* Launch Touchscreen Timer /
TouchScreenTimer = xTimerCreate (“Timer”, 50, pdTRUE, ( void ) 1, vTimerCallback );if( TouchScreenTimer != NULL )
if( xTimerStart( TouchScreenTimer, 0 ) != pdPASS )
/* The timer could not be set into the Active state. */
}xTaskCreate(Background_Task2, (<span style="color: #333399; font-weight: bold">signed</span> <span style="color: #333399; font-weight: bold">char</span> <span style="color: #008800; font-weight: bold">const</span><span style="color: #333333">*</span>)<span style="background-color: #fff0f0">"BK_GND"</span>, Demo_Task_STACK2, <span style="color: #007020">NULL</span>, Demo_Task_PRIO2, <span style="color: #333333">&</span>Demo_Handle2);
xTaskCreate(Background_Task3,
(signed char const*)“BK_GND”,
Demo_Task_STACK,
NULL,
Demo_Task_PRIO,
&Demo_Handle);CreateTestGuiBig(); <span style="color: #008800; font-weight: bold">while</span>(<span style="color: #0000DD; font-weight: bold">1</span>) { GUI_Delay(<span style="color: #0000DD; font-weight: bold">10</span>); }
static void Background_Task2(void * pvParameters)
{while(1) {
if((Graphflag==1)||(Graphflag==2)){
GRAPH_DATA_YT_AddValue(hData1, 60*ValLED3);
vTaskDelay(1);
}static void Background_Task3(void * pvParameters)
while(1) {
Demo_GyroReadAngRate(Buffer1);Buffer1[0] = (int8_t)Buffer1[0]- (int8_t)Gyro1[0];
Buffer1[1] = (int8_t)Buffer1[1] - (int8_t)Gyro1[1];/* Update autoreload and capture compare registers value*/
Xval1 = ABS((int8_t)(Buffer1[0]));
Yval1 = ABS((int8_t)(Buffer1[1]));<span style="color: #008800; font-weight: bold">if</span>((IMUflag<span style="color: #333333">==</span><span style="color: #0000DD; font-weight: bold">1</span>)<span style="color: #333333">||</span>(IMUflag<span style="color: #333333">==</span><span style="color: #0000DD; font-weight: bold">2</span>)){ GRAPH_DATA_YT_AddValue(hData2, Xval1 ); GRAPH_DATA_YT_AddValue(hData3, Yval1 ); } vTaskDelay(<span style="color: #0000DD; font-weight: bold">1</span>); }
