I’m rewriting a project to work on top of freeRTOS, and I will need fatfs (readonly). I want to be able to able to pack the directory structure in one file, send it to the MCU over TCP, and then the MCU will write it to external spi flash.
The packing should done with no conversion, so that the MCU, will just write byte by byte to external spi flash.
Everything is figured out, except for the packing part. Anyone has any suggestion to accomplish this?
