Hello All,
When I tried to run
idf.py -DVENDOR=espressif -DBOARD=esp32_wrover_kit -DCOMPILER=xtensa-esp32 build
according to
freertos/latest/userguide/getting_started_espressif.html#download-and-configure-espressif-idf42
I got this error
-- Configuring done
-- Generating done
-- Build files have been written to: E:/Connect_to_AWS_Greengrass_-_ESP32-DevKitC/FreeRTOS/build
Running ninja in directory e:\connect_to_aws_greengrass_-_esp32-devkitc\freertos\build
Executing "ninja all"...
[0/2] Re-checking globbed directories...
[1/1588] Building C object CMakeFiles/afr_crypto.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj
**FAILED**: CMakeFiles/afr_crypto.dir/vendors/espressif/esp-idf/components/mbedtls/port/esp32/bignum.c.obj
E:\ESP32\xtensa-esp32-elf\bin\xtensa-esp32-elf-gcc.exe -DAFR_ESP_LWIP -DESP_PLATFORM -DIDF_VER=\"v4.4-dev-2533-g83956ebbae\" -DMBEDTLS_CONFIG_FILE=\"E:/Connect_to_AWS_Greengrass_-_ESP32-DevKitC/FreeRTOS/vendors/espressif/esp-idf/components/mbedtls/port/include/mbedtls/esp_config.h\" -D_GNU_SOURCE -I../libraries/freertos_plus/standard/crypto/include -I../vendors/espressif/esp-idf/components/mbedtls/port/include -I../vendors/espressif/esp-idf/components/xtensa/include -I../vendors/espressif/esp-idf/components/soc/soc/include -I../vendors/espressif/esp-idf/components/soc/src/esp32/include -I../libraries/3rdparty/pkcs11 -I../libraries/3rdparty/mbedtls/include -I../libraries/3rdparty/mbedtls_config -I../libraries/3rdparty/mbedtls/include/mbedtls -I../libraries/3rdparty/mbedtls_utils -I../vendors/espressif/esp-idf/components/lwip/
so if anyone can support it will be great.
Thanks,
