Hello All, I would like to run FreeRTOS on RISC-V+QEMU to process ethernet frames. Do you have any libraries or sample programs for ethernet frame processing? Is there any other way than porting NetworkInterface.c in FreeRTOS-Plus-TCP for RISC-V?
Appreciate any helps.
If you just need to process Ethernet buffer, you can try to extract that code from FreeRTOS+TCP - FreeRTOS-Plus-TCP/source/FreeRTOS_IP.c at main · FreeRTOS/FreeRTOS-Plus-TCP · GitHub
On the other hand, if you need a complete TCP stack, you can port FreeRTOS+TCP as you said.
