ERROR: MQTT echo failed to connect with error 1. on STM32L4
jacksocket wrote on December 10, 2018:
Hi there,
I have exactly the same problem. I created a new thing more than once and followed the instructions exactly. But it doesn´t work with the B-L475-IOT01A1 board. I received the same error message like webcow. When I use a Raspberry Pi instead of the ST-Board it works. So I think, it´s not an issue of the endpoint. What can I do to get it work with the ST-Board? Thanks in advance.
