I have been facing several crashes on the program I’m developping mainly due to uninitialised pointers and such.
Being in a multitasking system does not make bug-hunting easier since things tend to happen in an asynchronously way.
I’m using Eclipse with GDB and J-Link,
I wonder if in the many windows and menu options provided by Eclipse I can get a better diagnostic of the reasons for a crash.
At the moment I’m facing a crash in mallocr() at 0x436a82 (see attachment)
It seems quite obvious taht the stack pointer register has a bad value (0xffffffac) but how can I find where this came from?
The code that seems problematic is when inside an ISR a Give semaphore operation is done:
if ( xSemaphoreGiveFromISR ( GNSS_Buffer_counter_semaphore, &xHigherPriorityTaskWoken ) != pdTRUE )
/* Fatal error but we are inside an interrupt routine */
SP_Printf_nmh ( "ERROR - GNSS_process_character() - Couldn't Give semaphore GNSS_Buffer_counter_semaphore" );
portYIELD_FROM_ISR ( xHigherPriorityTaskWoken );
where ucCurrentPriority is 0 and ucMaxSysCallPriority is 160 (A0h).
There is a very interesting big comment above the ASSERT:
Interrupts that use the FreeRTOS API must not be left at their
default priority of zero as that is the highest possible priority,
which is guaranteed to be above configMAX_SYSCALL_INTERRUPT_PRIORITY,
and therefore also guaranteed to be invalid.
There are some Eclipse tools, such as Atollic, that will give you a
stack trace back to the offending instruction from inside of a fault
handler - although it is possible to do that manually to - there is code
on the FreeRTOS.org site that shows you how. https://www.freertos.org/Debugging-Hard-Faults-On-Cortex-M-Microcontrollers.html
Additionally there are premium hardware tools that will enable you to
put watchpoints on data so you can set a breakpoint if data you know is
getting corrupted changes.
