Does it have test reports for each Kernel tag?
Is there a test result report available for the Kernel after the tag?
A number of checks, including unit tests, are run on every PR using GitHub Actions. Any failed check blocks the PR. The results of those can be accessed from GitHub UI. There is no other test report. What do you want to do with it?
I am attempting to run the tests in the project. I want the reports as a reference to ensure I am on the right track.
Thank you, for the help!
Which tests are you trying to run?
If you share your results, we can try to help.
