DHCP Malformed Packet
atemax wrote on Tuesday, March 14, 2017:
I run FreeRTOS+TCP Labs Build 150114 example and sniffing DHCP packet with wireshark I see many packet with [Malformed Packet], after few hours (lease time is 10 minutes for testing) the ip address of the board is set to default ip address.
Someone have the some problem ?
Thank you
Massimo
heinbali01 wrote on Thursday, March 16, 2017:
Hi Massimo, you are using one of the oldest Labs releases (from January 2015). The current release is 160919.
I recommend that you upgrade your project to that version. You may also upgrade the kernel (to 9.0.0) but that isn’t necessary.
But as I haven’t seen malformed DHCP packets yet, could you attach a small PCAP file that shows some of those packets?
You can filter DHCP packets with “udp.port==67”
