Device provisioning - JITP and JITR
DanG-AWS wrote on September 19, 2019:
Hello. Regarding createThing and createCertificateFromCsr, that is a supported mechanism for obtaining AWS IoT client certificates for Amazon FreeRTOS. However, those are considered to be “control plane” operations, and authenticated by some type of deployment administrator login, and therefore not something that would typically be executed on a microcontroller based device. Those APIs have been added to our Java SDK, but not to our Embedded C SDK, for that reason.
Technically, you could use the above for lab testing on an Amazon FreeRTOS device by generating a keyset on your PC (e.g. using openssl), completing the steps above, and then importing that keyset and the issued certificate onto your device.
Regarding your other points:
1/ Yes.
2/ Yes. Please also see https://github.com/aws/amazon-freertos/blob/master/demos/dev_mode_key_provisioning/README.md.
3/ Yes: the AWS IoT gateway needs the client certificate as well as the issuing CA certificate during the first connection attempt in the JITR scenario in order to route the request correctly. However, once JITR has completed and the device certificate is activated, the device no longer needs to send the CA certificate during MQTT broker connection attempts.
4/ Yes, per #3, above.
