neicdech wrote on Monday, February 11, 2019:
Hello All,
I am working on a FreeRTOS project on mcuxpresso , ksdk 2.5 and cortex m4 and at the moment, I simply want to get a task to blink an LED. The project runned without problems when the task function was defined in the main.c file. For clarity, I moved the LED task into its its own “User_task_function.c” and included the “User_task_function.h” in the main. Afterwards, the program will raise a hardware fault in the LED task when it calls DelayUntil(). I have tried for several days. I will appreciate help in resolving this issue. I have attached the project.
#ifdef __cplusplus
extern “C” {
#include "MK22F51212.h"
#include "fsl_clock.h"
#include "clock_config.h"
#include "Defs.h"
#include "FreeRTOS.h"
#include "task.h"
#include "semphr.h"
#include "timers.h"
#include "queue.h"
#include "fsl_port.h"
#include "fsl_gpio.h"
#include "global_variable.h"
#include "user_task_functions.h"
#include "pins.h"
#include "pin_mux.h"
#ifdef cplusplus
int main ()
BOARD_BootClockHSRUN();
BOARD_InitBootPins();
if (xTaskCreate(air_blinky, "air_blinky_A", 200, &Board_A_blinky, blinkyPriority,
&BlinkyAhandle) == errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY)
exit(-1);
vTaskStartScheduler();
while(true);
return 0;
// Below is the Header for the task function.
#ifndef USER_TASK_FUNCTIONS_H_
#define USER_TASK_FUNCTIONS_H_
#include “Defs.h”
#include “FreeRTOS.h”
#include “task.h”
#include “global_variable.h”
#include “fsl_gpio.h”`
void air_blinky(void* blinky_parameters);
void vApplicationIdleHook( void );
`#endif /* USER_TASK_FUNCTIONS_H_ */``
// Below is the task functions definition
`#include “user_task_functions.h”
volatile BLINKY_param_t* LED = (BLINKY_param_t*) blinky_parameters;
char* Mytaskname = pcTaskGetName(NULL);
TickType_t xBlinkyLastwakeuptime = xTaskGetTickCount();
const TickType_t Flash_Time = 100;
const TickType_t Flash_Return_Time = 2000;
GPIO_PortClear(LED->GPIO, mask(LED->Pin_name)); // on
for (;;)
if( isTasksuspended & (!(strcmp(Mytaskname,"air_blinky_A")) ? 0b10000000 : 0b00010000) ) // area to publish a paper on
portTICK_TYPE_ENTER_CRITICAL();
isTasksuspended &= ( (!(strcmp(Mytaskname,"air_blinky_A"))) ? 0b01111111 : 0b11101111 ) ;
portTICK_TYPE_EXIT_CRITICAL();
GPIO_PortClear (LED->GPIO, mask(LED->Pin_name));
GPIO_PortToggle (LED->GPIO, mask(LED->Pin_name));
vTaskDelayUntil (&xBlinkyLastwakeuptime,Flash_Time);
vTaskDelayUntil (&xBlinkyLastwakeuptime, Flash_Return_Time);
// Below is the header for the global variables
#ifndef GLOBAL_VARIABLE_H_
#define GLOBAL_VARIABLE_H_
#include "stdint.h"
#include "stddef.h"
#include "task.h"
#include "semphr.h"
#include "Defs.h"
#include "pins.h"
#include "arm_math.h"
extern uint8_t isTasksuspended ;
extern BLINKY_param_t Board_A_blinky ;
extern BLINKY_param_t Board_B_blinky ;
extern TaskHandle_t BlinkyAhandle ;
extern TaskHandle_t BlinkyBhandle ;
extern TaskHandle_t MasterTaskhandle ;
extern SemaphoreHandle_t INTERRUPT_semphr ;
extern bool ActuatorOneDetectState ;
extern bool ActuatorTwoDetectState ;
extern arm_biquad_casd_df1_inst_f32 NoiseFilter ;
extern float32_t corrupt_dataA[Blocksize];
extern float32_t corrupt_dataB[Blocksize];
extern float32_t outputA[Blocksize] ;
extern float32_t outputB[Blocksize] ;
#endif /* GLOBAL_VARIABLE_H_ */
// Below is my global variables
`#include “global_variable.h”
uint8_t isTasksuspended = 0;
BLINKY_param_t Board_A_blinky = { GPIOE, PTE1 } ;
BLINKY_param_t Board_B_blinky = { GPIOB, PTB22} ;
TaskHandle_t BlinkyAhandle = NULL ;
TaskHandle_t BlinkyBhandle = NULL ;
TaskHandle_t MasterTaskhandle = NULL ;
SemaphoreHandle_t INTERRUPT_semphr = NULL ;
bool ActuatorOneDetectState = false ;
bool ActuatorTwoDetectState = false ;
float32_t corrupt_dataA[Blocksize] = {0} ;
float32_t corrupt_dataB[Blocksize] = {0} ;
float32_t outputA[Blocksize] = {0} ;
float32_t outputB[Blocksize] = {0} ;
