chaabanemalki wrote on Wednesday, April 23, 2014:
I set up a project based using Mplab X ide 2.00 and XC32 1.31 and i added FreeRTOS kernel, For now FreeRTOs manages the heap with heap_4.c.
I noticed when I check “enable App IO” from Project Properties>x32-gcc, and add this line in the beginning of main(), after DBINIT()
char valueTest[]=“this is a test\n”;
When I start debugging, the value of valueTest doesn’t change, yet when i print it with DBRINTF()
I get “this is a t” in the PIC AppIO window.
If I uncheck “enable App IO” I can see the value of valueTest changing in the watches window
I know that DBPRINTF uses the heap space, and FreeRTOs reserve around 28k but i’m not sure if this space is shared with DBPRINTF().
I also found that I can use functions in printf-stdarg.c rather than standard C libraries. Is it possible to replace BDPRINTF with PRINTF from printf-stdarg.c
Any ideas how to fix this problem ?
Thank you
any ideas how to fix this problem ???
