I am using ARM Crossworks 2.2 and FreeRTOS 7.1.1 and trying to compile to a MCB1700 Keil target. After applying the notes on adding extra paths to the preprocessor it still fails to compile in the USB section, with messages that structures such as USB-> aren’t defined. They do seem to have ben assigned in in LPC17xx.h.
Has anyone managed to build to this target, and if so have they any comments?
There is an example in the FreeRTOS download. Look in the \Demo\CORTEX_LPC1768_GCC_Rowley folder. It might not be for the MCB1700 exactly but it should build.
Thanks Dave, this is the example I am trying to build, and no at present I don’t intend to use the uSB, but it isn’t a promising start, I suspect I could remove the USB from the build, but I have a niggling fear, that if it won’t compile after it seems to have been assigned, it is only the start of my problems.
