# Crash in Windows port
**URL:** <https://forums.freertos.org/t/crash-in-windows-port/15687>\
**Category:** Kernel\
**Created:** [August 24, 2022, 6:26am UTC](https://forums.freertos.org/t/crash-in-windows-port/15687 "2022-08-24T06:26:42Z")\
**Showing post:** 3
**Author:** ![Fojtik](https://d3iykfbgfh8zhg.cloudfront.net/user_avatar/forums.freertos.org/fojtik/32/2807_2.png) [@Fojtik](https://forums.freertos.org/u/Fojtik)\
**Post date:** [August 24, 2022, 6:14pm UTC](https://forums.freertos.org/t/crash-in-windows-port/15687/3 "2022-08-24T18:14:34Z")
Hi Richard Barry, I know all that you write, but it did not solve my problem.
I need to ABORT FreeRTOS and continue application. I have already proposed full workable fix to FreeRTOS here: [I need to exit FreeRTOS without aborting whole Windows application](https://forums.freertos.org/t/i-need-to-exit-freertos-without-aborting-whole-windows-application/15059)
Why? I has been used Aerosim-RC (absolutelly no control over Aerosim threads) and a code from UAV MCU autopilot compilled to Windows: [Autopilot for UAV's](http://www.penguin.cz/~fojtik/autopilot/autopilot.htm)
and bind them together.
Nobody before me has been solved clean FreeRTOS shutdown to Windows. First I have wrong suspection, that there is only a minor bug in FreeRTOS, but the correct solution resulted to create bunch of a new code.
May be that this thread moved from Source Forge is just a duplicity.
I did not solve it 100% correct, but FreeRTOS finishes correctly in 99%. It is very good that I do
not need to restart Aerosimulator so often.
_[View the full topic](https://forums.freertos.org/t/crash-in-windows-port/15687)._
