Authors of Cortex-M3 MPU port, did you tried compile it with configUSE_MUTEXES = 1 ?
port.c: In function ‘MPU_xQueueCreateMutex’:
port.c:973:3: error: too few arguments to function ‘xQueueCreateMutex’
\FreeRTOS\include/queue.h:1227:14: note: declared here
Thank you for pointing this out. This issue will have been introduced in the latest FreeRTOS release which had some internal (not visible to end users) changes to better support the FreeRTOS+Trace tool. I will fix it.
The MPU port was fully tested when it was created. The reason you are seeing these problems is mentioned in post two in this thread - and relates to changes to the prototype of the queue create function in the last release.
