There is nothing like an “unknown state.” Either your code has caused an exception, so your pc points to somewhere in a fault handler, or you are stuck in an infinite loop, or all your tasks are suspended or blocked. In either case, you first look at the pc value and determine which code belongs to it.
right, but 0x00000a60 being the PC value I reckon, but would you track what it corresponds to? I’m using Segger IDE and I entered this address in the memory search bar but it doesn’t quite help
Is it reproducible or does it happen sporadically ?
Is it possible that e.g. the sensor object gets corrupted/deleted ?
Are you sure that the (rather small) task stack size of 250 is really sufficient ?
It does seem to happen every time. If not right away, it would happen a few seconds later.
How would the object getting corrupted at a random instance? Note that the object is created in global scope of main and its reference gets stored inside SystemTask so I doubt if it’s getting corrupted.
For now I still see a fair amount of memory hasn’t been used
Seems something bad happens when using/reading the sensor (?). Perhaps a problem with the underlying driver. The higher level task/object setup as you described seems to be ok.
It’s not “random,” rather “indeterministic.” That’s the very nature of concurrent programming and the daily work of all of us.
Assume that some task’s stack gets overwritten, corrupting memory that “belongs to someone else.” Now the problem only occurs once this “someone else” attempts to do something with that memory. That may happen rather soon, but then again there may be multiple interrupts being serviced in the meantime, higher pri tasks being scheduled and so on. It is very typical and normal that crashes or other problems manifests themselves in different ways and places depending on the concurrent (unpredictable) sequence of events.
If you’ve been doing RTOS work for y few years, you’ll develop a fairly reliable gut feeling for the usual suspects for the root cause instead of trying to look at the crash itself.
