# CMake project setup issues with AWS FreeRTOS for ESP32
**URL:** <https://forums.freertos.org/t/cmake-project-setup-issues-with-aws-freertos-for-esp32/13229>\
**Category:** AWS\
**Created:** [August 13, 2021, 8:23am UTC](https://forums.freertos.org/t/cmake-project-setup-issues-with-aws-freertos-for-esp32/13229 "2021-08-13T08:23:50Z")\
**Showing post:** 2
**Author:** ![gedeonag](https://d3iykfbgfh8zhg.cloudfront.net/user_avatar/forums.freertos.org/gedeonag/32/479_2.png) [@gedeonag](https://forums.freertos.org/u/gedeonag)\
**Post date:** [August 13, 2021, 6:06pm UTC](https://forums.freertos.org/t/cmake-project-setup-issues-with-aws-freertos-for-esp32/13229/2 "2021-08-13T18:06:23Z")
Hi @SimonCB,
Is your problem similar to this one?
> [@How do I link amazon freertos to my project](https://forums.freertos.org/t/how-do-i-link-amazon-freertos-to-my-project/13210/7):
> Hi @gedeonag I this is my current CMakelists.txt cmake\_minimum\_required(VERSION 3.13) project(my\_app) add\_executable(${PROJECT\_NAME} src/main.c) set(IDF\_PROJECT\_EXECUTABLE ${PROJECT\_NAME}) # Add FreeRTOS as a subdirectory. AFR\_BOARD tells which board to target. set(AFR\_BOARD cypress.CY8CKIT\_064S0S2\_4343W CACHE INTERNAL "") set(AFR\_TOOLCHAIN arm-gcc CACHE INTERNAL "") add\_subdirectory(freertos) # Link against the mqtt library so that we can use it. Dependencies are transitively # linked. …
_[View the full topic](https://forums.freertos.org/t/cmake-project-setup-issues-with-aws-freertos-for-esp32/13229)._
