CM4F Assertion in port.c after update to V11.0.1
I’ve continued evaluating the problem in the debugger by adding some debug variables. This shows why the assertion fails.
volatile uint32_t test3257 = 5;
volatile uint32_t test3258 = 6;
volatile uint32_t test3259 = 7;
void vTaskStepTick( TickType_t xTicksToJump )
    TickType_t xUpdatedTickCount;
    traceENTER_vTaskStepTick( xTicksToJump );
    /* Correct the tick count value after a period during which the tick
     * was suppressed.  Note this does *not* call the tick hook function for
     * each stepped tick. */
    test3257 = xTickCount;
    test3258 = xTicksToJump;
    xUpdatedTickCount = test3257 + test3258;
// xUpdatedTickCount = xTickCount + xTicksToJump;
    test3259 = xNextTaskUnblockTime;
    configASSERT( xUpdatedTickCount <= test3259 );
// configASSERT( xUpdatedTickCount <= xNextTaskUnblockTime );
test3257 is set to a value of 20009FFF₁₆, which is the end of RAM and not the tick count. The other two test variables are correct. This triggers the exception.
the corresponding assembly is
4574 test3257 = xTickCount;
08005d60: ldr r3, [pc, #228] ; (0x8005e48 <prvIdleTask.lto_priv.55+636>) // load addr of variable test3257 to r3
08005d62: ldr r2, [r7, #0] //load value of xTickCount by de-referencing r7
08005d64: str r2, [r3, #0] //store
the line where r7 is set to the address of xTickCount is before entering/leaving sleep mode. Any idea if this might cause the problem?
Another strange thing is, this happens only on power-up / cold boot, not on reset. After a reset the values are correct and the system boots normally.
