CellularLib: Error in processing RAT. Token 11
You can use psRegStatus ( packet switch registration status ) in CEREG URC for cellular_state if your module is registered on the LTE network Cat M1.
csRegStatus ( circuit switch registration status ) in CREG URC is for circuit switch network. It is not required if you are using Cat M1 network.
