sasikalaswathi wrote on Monday, September 09, 2019:
Can we manually call the schedular to switch to another task before the given time slice happens in a task by dynamically allocating priority inside a task?Is it used anywhere?
rtel wrote on Monday, September 09, 2019:
Yes, call taskYIELD(): https://www.freertos.org/a00020.html#taskYIELD
sasikalaswathi wrote on Tuesday, September 10, 2019:
Hi Richard, thanks for the response
What if I Increase the priority of another tasks inside one task, in that case also the scheduler will switch to another task before the given time slice, would’nt it?
richard_damon wrote on Tuesday, September 10, 2019:
If you do an action that makes another task a higher priority unblock task, then that operation will also switch to that task. Changing priority of an unblocked task will work, as will doing something that unblocks a higher priority task.
