# CAN message gets corrupt inside a FreeRTOS task
**URL:** <https://forums.freertos.org/t/can-message-gets-corrupt-inside-a-freertos-task/12766>\
**Category:** Kernel\
**Created:** [June 3, 2021, 7:37am UTC](https://forums.freertos.org/t/can-message-gets-corrupt-inside-a-freertos-task/12766 "2021-06-03T07:37:36Z")\
**Showing post:** 10
**Author:** ![hs2](https://avatars.discourse-cdn.com/v4/letter/h/a4c791/32.png) [@hs2](https://forums.freertos.org/u/hs2)\
**Post date:** [June 3, 2021, 10:08am UTC](https://forums.freertos.org/t/can-message-gets-corrupt-inside-a-freertos-task/12766/10 "2021-06-03T10:08:00Z")
Yes. With this setting the interrupts have the highest possible priority covered by FreeRTOS.
Cortex-M interrupt priorities are not easy to get right.
IMO this post [Understanding priority levels of ISR and FreeRTOS APIs - #16 by aggarg](https://forums.freertos.org/t/understanding-priority-levels-of-isr-and-freertos-apis/10453/16) contains a good and easy to understand explanation. [This](https://forums.freertos.org/t/interrupt-priority-for-cortex-m-series-configlibrary-max-syscall-interrupt-priority/7058) is also a good posting.
_[View the full topic](https://forums.freertos.org/t/can-message-gets-corrupt-inside-a-freertos-task/12766)._
