wowbagger wrote on Friday, April 04, 2008:
FreeRTOS 4.7.x port dsPIC
The highwater mark field does not work for processors that have
portSTACK_GROWTH == 1.
There is no work around as the tasks stack length is not stored in the TCB structure.
I have modified my copy to do so and also added a function to return current stack hw mark
As a side note:
Blowing the stack is a common problem during embedded development and is a common source of hard to find errors.
FreeRTOS would be a better product with better stack monitoring or checking facilites ( like RTEMS for example).
Cheers.
