baduf wrote on Wednesday, February 11, 2015:
STM32Cube from ST micro provides project code generation for FreeRTOS along with a wrapper dedicated to use of the CMSIS-OS API.
Nevertheless, it seems that this wrapper is brocken regarding the FreeRTOS API function “vTaskDelayUntil()” wich is wrapped to “osDelayUntil()” according to the following code from cmsis_os.c:
* @brief Delay a task until a specified time
* @param PreviousWakeTime Pointer to a variable that holds the time at which the
* task was last unblocked.
* @param millisec time delay value
* @retval status code that indicates the execution status of the function.
osStatus osDelayUntil (uint32_t PreviousWakeTime, uint32_t millisec)
#if INCLUDE_vTaskDelayUntil
portTickType ticks = (millisec / portTICK_RATE_MS);
portTickType previouswake = (portTickType) PreviousWakeTime;
vTaskDelayUntil(&previouswake, ticks ? ticks : 1);
return osOK;
#else
(void) millisec;
(void) PreviousWakeTime;
return osErrorResource;
In the freeRTOS API, the first argument of this function is a pointer to a variable that holds the time at which the task was last unblocked and this variable is automatically updated within vTaskDelayUntil(). Nevertheless, as you can note, the wrapper don’t use a pointer anymore. That is, the local variable couldn’t be updated anymore and the function is unusable.
I’m not sure that it is the right place for reporting it, but I don’t know where to do so…
Many thanks in advance for your help.
Best regards,
BaDuf
