Hi
Has anyone done this / got some suggestions on the best place to throttle the transfer rate on the FTP server- I need to restrict the transfer rate since i have real time, UDP data flying around, lots of it. I dont want the FTP system taking up as much as it can, even with the low priority that it runs at. -
I probably dont need to throttle by speed, just PPS would be enough so putting in a vtaskDelay() in the transfer function somewhere is probably the best means.
I have put a vtask delay of 30mS into the read and write loops- the top of the loop.
10mS yielded 315 kbytes/sec RW in/out of RAMdisk (DDR4, 600 MHz cortex A53 Xilinx).
30mS yielded 105 kBytes/sec
Hi Hein
yes, that’s a good point, I should have a look on wireshark and see what it is doing .
Probably limiting the number of outstanding segments is the best choice, together with the pacing delays.
The effect of the pacing delay I think depends on how many other buffers are elsewhere. A wifi link might behave very differently to a wired link.
I have this right now for config. MSS is about 650 bytes. MTU is 1200.
