travfrog wrote on Monday, November 12, 2012:
If the system I am working on detects a failure condition, it is required to lock up and flash a single LED. This is done in a simple loop using cycle counts for the LED flashing - no RTOS timers.
Is simply disabling all interrupts ensure the RTOS stops running? There is no intention to restart the RTOS once this has happened so state information is not important.
