Hi, I’m using FreeRTOS to write code for a music system and need to be able to save several states simultaneously (boot status, play status, source selected etc). Normally I would do this by having a global struct which contains several enums for each state.
Is there a different/more appropriate way to accomplish saving states in FreeRTOS? I’m fairly new to the RTOS world, so excuse me if I’ve missed something obvious here.
Many thanks
I am an advocate of “the simplest way that works” - in this case the only reason not to continue to use the structure would be if multiple tasks need to write to the structure at the same time - in which case you would need to use some form of mutual exclusion primitive to ensure one task does not corrupt what another task is doing.
