If you declare a local 60 byte array then the compiler will place the array on the stack of the task. Every task has its own stack, so every task will have its own array, so it is a thread-safe way of doing it. This is a fast and neat way of allocating a 60 byte buffer - but it will mean the size of the stack allocated to the task will have to be large enough to hold it. See http://www.freertos.org/Stacks-and-stack-overflow-checking.html
If you dynamically allocate a buffer by calling pvPortMalloc(), and store a pointer to the buffer in a local variable (pBuffer in your case) then that variable will be either on the stack of the task or in a register. Every task has its own stack, and its own pseudo-copy of the registers - so again this is thread safe. Dynamically allocating the buffer is much slower than just declaring an array on the stack, but will allow you to allocate a smaller stack to the task.
Thank you for the clarification.
So if I understood right. In the example I showed above, case 2 :
the compiler will place and 60 bytes array the stack of task1 and another 60 bytes in the stack of functionA ? am I right ?
In case 1, you have 60 bytes allocated on the task1 stack, so you need to make sure that you give task1 enough stack to store it.
In case 2, you have 60+ bytes allocated on the heap (it is + as allocations on the heap often require some overhead bytes to operate with them, and the allocation is often rounded up to some increment), and a pointer on the stack (likely 2 or 4 bytes long). This means you will need to make sure the heap has enough space to allocate the object out of.
