AFR & ESP32: How to INCLUDE -isystem ../libraries/3rdparty/jsmn for using JSMN library with MQTT Demo?
Namaste Forum Member,
Below is a sample MQTT Publish payload, which I would like to publish in JSON format on the AWS IoT web console.
      "timestamp": 1600176543,
      "deviceId": "esp32DevKitCBoard01",
      "param01": 012345.67,
      "param02": 678901.23
After browsing the OTA Update demo code, I found the …/libraries/3rdparty/jsmn library, which the OTA Update demo leverages for receiving an OTA update. So, I am trying to use this library for converting my Publish payload in JSON format, before calling the IotMqtt_Publish().
#include "jsmn.h" in the iot_demo_mqtt.c source file generates fatal error: jsmn.h: No such file or directory
In the build.ninja log for OTA Update demo, I have observed that the OTA Update source files build with an additional INCLUDE = -isystem ../libraries/3rdparty/jsmn.
Sample build command for the aws_iot_ota_agent.c source file is provided below. Scroll to the extreme right to view the same.
build CMakeFiles/afr_ota.dir/libraries/freertos_plus/aws/ota/src/aws_iot_ota_agent.c.obj: C_COMPILER__afr_ota_ ../libraries/freertos_plus/aws/ota/src/aws_iot_ota_agent.c || cmake_object_order_depends_target_afr_ota
  DEFINES = -DAFR_ESP_LWIP -DESP_PLATFORM -DGCC_NOT_5_2_0=0 -DHAVE_CONFIG_H -DIDF_VER=\"v3.3-163-g601a03e\" -DMBEDTLS_CONFIG_FILE=\"D:/gitHub/dipen-1337lab/repositories/evcharging/devV2/evcharging/device/firmware/aws/proj04/FreeRTOS/vendors/espressif/boards/esp32/components/mbedtls/port/include/mbedtls/esp_config.h\"
  DEP_FILE = CMakeFiles\afr_ota.dir\libraries\freertos_plus\aws\ota\src\aws_iot_ota_agent.c.obj.d
  FLAGS = -mlongcalls   -mlongcalls -Og -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -std=gnu99 -Wno-old-style-declaration -Wno-maybe-uninitialized
  INCLUDES = -I../libraries/freertos_plus/aws/ota/src -I../libraries/3rdparty/mbedtls/include -I../libraries/freertos_plus/aws/ota/include -I../libraries/freertos_plus/standard/crypto/include -I../freertos_kernel/include -I../vendors/espressif/esp-idf/components/app_update/include -I../vendors/espressif/esp-idf/components/bootloader_support/include -I../vendors/espressif/esp-idf/components/esp32/include -I../vendors/espressif/esp-idf/components/esp_event/include -I../vendors/espressif/esp-idf/components/efuse/include -I../vendors/espressif/esp-idf/components/driver/include -I../vendors/espressif/esp-idf/components/heap/include -I../vendors/espressif/esp-idf/components/log/include -I../vendors/espressif/esp-idf/components/nvs_flash/include -I../vendors/espressif/esp-idf/components/pthread/include -I../vendors/espressif/esp-idf/components/newlib/include -I../vendors/espressif/esp-idf/components/newlib/platform_include -I../vendors/espressif/esp-idf/components/soc/esp32/include -I../vendors/espressif/esp-idf/components/soc/include -I../vendors/espressif/esp-idf/components/spi_flash/include -I../vendors/espressif/esp-idf/components/vfs/include -I../vendors/espressif/boards/esp32/components/freertos/include -I../vendors/espressif/boards/esp32/components/mbedtls/port/include -I../vendors/espressif/esp-idf/components/tcpip_adapter/include -I../freertos_kernel/portable/ThirdParty/GCC/Xtensa_ESP32/include -I../firmware/include -I../vendors/espressif/boards/esp32/proj04/config_files -Iconfig -I../libraries/freertos_plus/standard/pkcs11/include -I../libraries/abstractions/pkcs11/include -I../libraries/c_sdk/standard/mqtt/include -I../libraries/c_sdk/standard/common/include -I../libraries/abstractions/platform/include -I../libraries/abstractions/platform/freertos/include -I../libraries/abstractions/secure_sockets/include -I../libraries/c_sdk/standard/common/include/private -I../libraries/c_sdk/standard/serializer/include -I../libraries/3rdparty/tinycbor -I../libraries/3rdparty/mbedtls/include/mbedtls -I../libraries/abstractions/pkcs11/mbedtls -I../libraries/c_sdk/standard/ble/include -I../libraries/abstractions/ble_hal/include -I../libraries/c_sdk/standard/https/include -isystem ../libraries/3rdparty/pkcs11 -isystem ../libraries/3rdparty/jsmn
  OBJECT_DIR = CMakeFiles\afr_ota.dir
  OBJECT_FILE_DIR = CMakeFiles\afr_ota.dir\libraries\freertos_plus\aws\ota\src
  TARGET_COMPILE_PDB = CMakeFiles\afr_ota.dir\afr_ota.pdb
  TARGET_PDB = afr_ota.pdb
The build.ninja log for the iot_demo_mqtt.c source file does include the -isystem ../libraries/3rdparty/pkcs11. The log is again shared below; scroll right towards the end. How do I also include the ‘-isystem …/libraries/3rdparty/jsmn’, so as to leverage the JSMN library?
build CMakeFiles/proj02.dir/firmware/mqtt/iot_demo_mqtt.c.obj: C_COMPILER__proj02_ ../firmware/mqtt/iot_demo_mqtt.c || cmake_object_order_depends_target_proj02
  DEFINES = -DESP_PLATFORM -DGCC_NOT_5_2_0=0 -DHAVE_CONFIG_H -DIDF_VER=\"v3.3-163-g601a03e\" -DMBEDTLS_CONFIG_FILE=\"D:/aws/proj02/FreeRTOS/vendors/espressif/boards/esp32/components/mbedtls/port/include/mbedtls/esp_config.h\"
  DEP_FILE = CMakeFiles\proj02.dir\firmware\mqtt\iot_demo_mqtt.c.obj.d
  INCLUDES = -I../freertos_kernel/include -I../vendors/espressif/esp-idf/components/app_update/include -I../vendors/espressif/esp-idf/components/bootloader_support/include -I../vendors/espressif/esp-idf/components/esp32/include -I../vendors/espressif/esp-idf/components/esp_event/include -I../vendors/espressif/esp-idf/components/efuse/include -I../vendors/espressif/esp-idf/components/driver/include -I../vendors/espressif/esp-idf/components/heap/include -I../vendors/espressif/esp-idf/components/log/include -I../vendors/espressif/esp-idf/components/nvs_flash/include -I../vendors/espressif/esp-idf/components/pthread/include -I../vendors/espressif/esp-idf/components/newlib/include -I../vendors/espressif/esp-idf/components/newlib/platform_include -I../vendors/espressif/esp-idf/components/soc/esp32/include -I../vendors/espressif/esp-idf/components/soc/include -I../vendors/espressif/esp-idf/components/spi_flash/include -I../vendors/espressif/esp-idf/components/vfs/include -I../vendors/espressif/boards/esp32/components/freertos/include -I../vendors/espressif/boards/esp32/components/mbedtls/port/include -I../vendors/espressif/boards/esp32/components/freertos_tcpip/ethernet/include -I../vendors/espressif/boards/esp32/components/freertos_tcpip/smartconfig_ack/include -I../vendors/espressif/boards/esp32/components/freertos_tcpip/tcpip_adapter/include -I../libraries/freertos_plus/standard/freertos_plus_tcp/source/portable/Compiler/GCC -I../freertos_kernel/portable/ThirdParty/GCC/Xtensa_ESP32/include -I../firmware/include -I../vendors/espressif/boards/esp32/proj02/config_files -Iconfig -I../vendors/espressif/esp-idf/components/bt/bluedroid/api/include/api -I../vendors/espressif/esp-idf/components/bt/include -I../vendors/espressif/esp-idf/components/nimble/nimble/porting/nimble/include -I../vendors/espressif/esp-idf/components/nimble/port/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/ans/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/bas/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/gap/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/gatt/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/ias/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/lls/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/services/tps/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/util/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/store/ram/include -I../vendors/espressif/esp-idf/components/nimble/nimble/nimble/host/store/config/include -I../vendors/espressif/esp-idf/components/nimble/nimble/porting/npl/freertos/include -I../vendors/espressif/esp-idf/components/nimble/nimble/ext/tinycrypt/include -I../vendors/espressif/esp-idf/components/nimble/esp-hci/include -I../vendors/espressif/boards/esp32/ports/ble -I../vendors/espressif/boards/esp32/ports/ble/bluedroid -I../vendors/espressif/boards/esp32/ports/ble/nimble -I../libraries/abstractions/wifi/include -I../libraries/c_sdk/standard/common/include -I../libraries/freertos_plus/standard/utils/include -I../libraries/abstractions/secure_sockets/include -I../libraries/c_sdk/standard/common/include/private -I../libraries/freertos_plus/standard/crypto/include -I../libraries/3rdparty/mbedtls/include -I../libraries/3rdparty/mbedtls/include/mbedtls -I../libraries/abstractions/pkcs11/mbedtls -I../libraries/c_sdk/standard/ble/include -I../libraries/abstractions/ble_hal/include -I../libraries/abstractions/platform/include -I../libraries/abstractions/platform/freertos/include -I../libraries/c_sdk/standard/serializer/include -I../libraries/3rdparty/tinycbor -I../vendors/espressif/esp-idf/components/esp_ringbuf/include -I../libraries/freertos_plus/standard/freertos_plus_tcp/include -I../vendors/espressif/esp-idf/components/micro-ecc/micro-ecc -I../vendors/espressif/esp-idf/components/efuse/esp32/include -I../vendors/espressif/esp-idf/components/xtensa-debug-module/include -I../vendors/espressif/esp-idf/components/app_trace/include -I../vendors/espressif/esp-idf/components/wpa_supplicant/include -I../vendors/espressif/esp-idf/components/wpa_supplicant/port/include -I../vendors/espressif/esp-idf/components/espcoredump/include -I../vendors/espressif/esp-idf/components/console -I../vendors/espressif/esp-idf/components/esp_adc_cal/include -I../vendors/espressif/esp-idf/components/expat/expat/expat/lib -I../vendors/espressif/esp-idf/components/expat/port/include -I../vendors/espressif/esp-idf/components/wear_levelling/include -I../vendors/espressif/esp-idf/components/sdmmc/include -I../vendors/espressif/esp-idf/components/fatfs/src -I../vendors/espressif/esp-idf/components/freemodbus/modbus/include -I../vendors/espressif/esp-idf/components/freemodbus/modbus_controller -I../vendors/espressif/esp-idf/components/nghttp/port/include -I../vendors/espressif/esp-idf/components/nghttp/nghttp2/lib/includes -I../vendors/espressif/esp-idf/components/openssl/include -I../vendors/espressif/esp-idf/components/spiffs/include -I../vendors/espressif/esp-idf/components/ulp/include -I../firmware/network_manager -I../firmware/dev_mode_key_provisioning/include -I../libraries/freertos_plus/standard/pkcs11/include -I../libraries/abstractions/pkcs11/include -I../libraries/c_sdk/standard/mqtt/include -isystem ../libraries/3rdparty/pkcs11
  OBJECT_DIR = CMakeFiles\proj02.dir
  OBJECT_FILE_DIR = CMakeFiles\proj02.dir\firmware\mqtt
  TARGET_COMPILE_PDB = CMakeFiles\proj02.dir\
  TARGET_PDB = proj02.pdb
Thanks | Regards,
Dipen
To be able to use jsmn, you need to declare a dependency on 3rdparty::jsmn here: https://github.com/aws/amazon-freertos/blob/master/demos/mqtt/CMakeLists.txt#L16
However, if you just want to construct JSON and not parse JSON, you can use simple snprintf like here: https://github.com/aws/aws-iot-device-sdk-embedded-C/blob/master/demos/shadow/shadow_demo_main/shadow_demo_main.c#L598
Namaste @aggarg,
Many thanks! I confirm that I’m able to include the JSMN library in the iot_demo_mqtt.c source file and, generate the binary image.
Yes, that’s the primary requirement. I need to format my Publish payload in the JSON format and send it to the Server/ Cloud. The message decoding shall be handled there. Thanks for this! I’ll explore this option.
Thanks | Regards,
Dipen
Namaste @aggarg,
Happy to share an update on publishing my JSON formatted MQTT payload to the AWS IoT console. Few sample readings can be viewed in the below attachment.
sampleReadings
This formula to calculate the size of the JSON doc, was a saviour as I was really struggling to view the JSON formatted payload on the AWS IoT console.
Thanks a ton man, for referring the shadow_demo_main.c! Appreciated. :smile: :+1:
Thanks | Regards,
Dipen
