larrydew wrote on Tuesday, June 04, 2019:
I am trying to add a new UDP protocol to my FreeRTOS project and reading the FreeRTOS+UDP Primer - A Step by Step Tutorial it says I must HEAP_4. I need to use Heap_5. Is this a true limitation?
rtel wrote on Tuesday, June 04, 2019:
Heap_4 and Heap_5 are basically the same, the latter just enables you to
split the memory used as the heap across multiple memory regions. Note
FreeRTOS+UDP was deprecated some time ago in favour of FreeRTOS+TCP,
which can be configured for UDP only operation. The +TCP code has and
continues to undergo memory safety proofs.
Thanks, I am in fact using +TCP code. I am also using +CLI and using it as an example of adding a UDP protocol since the interpretor uses a UDP socket.
