accessor func issue with file-scope variable
oahmad2 wrote on Thursday, July 07, 2011:
Hi
I am having a bizarre issue and I just want to know if it is an RTOS issue.
I have a local file-scope array static double MeasValues; in a file called measurements.c
This array has individual measurements located within it such as temp, press, flow, etc.
I have an accessor function defined in this same file to provide a get_ for these measurements; an example is:
**double blck_getFlowMeasurement(void)
double flow;
if(xSemaphoreTake(measMutex, portMAX_DELAY) == pdTRUE)
flow = MeasValues;
xSemaphoreGive(measMutex);
return flow;
This local variable is being updated in the measurements.c file as follows:
**static void measTask( void *pvParameters )
int i;
portTickType xLastWakeTime;
xLastWakeTime = xTaskGetTickCount();
for( ;; )
if(xSemaphoreTake(measMutex, portMAX_DELAY) == pdTRUE) //updating the measurements
/*todo
* 1. store these measurements locally - done
* 2. provide access to other external functions
* 3. to these values
printDebug("<MEASTask>\r\n");
for(i=0; i <NumMeas; i++)
if(*(Measurements_.MeasFuncPtr) != NULL)
ADC_Values = readADC(Measurements.adc, Measurements.adcChannel);
MeasValues = Measurements.MeasFuncPtr(countsToVolts(Measurements.adc, ADC_Values));
xSemaphoreGive(measMutex); //done updating measurements
//block until period is over
vTaskDelayUntil( &xLastWakeTime, ( MEAS_TASK_PERIOD_in_ms / portTICK_RATE_MS ) );
In another file called **view.c **I call this function periodically to get the value for these variables:
static void blck_viewTask( void *pvParameters )
    char tmpString;
    int hr, min, sec;
    double test;
    xSemaphoreTake(getRTCSemaphore(),portMAX_DELAY);
   ** for( ;; )
    //block read on RTC
    blck_readRTC(&hr, &min, &sec);
    printDebug(“viewtask\r\n”);
        sprintf(tmpString, “%2.1f\r\n”, blck_getFlowMeasurement());
        printDebug(tmpString);
        /* Allow the other sender task to execute. */
        //taskYIELD();
I am running into an issue where the values returned from the function blck_getFlowMeasurement() is 0.0.
Any ideas as to why it is not working?  I also created a local variable to read this value and I get a huge random variable.
Is there something from an RTOS perspective that might be causing this?
_
edwards3 wrote on Thursday, July 07, 2011:
Not unless you tell us which chip you are using, which compiler you are using, and which libraries you are using for printf.
http://www.freertos.org/FAQ-how-to-use-the-FreeRTOS-support-forum.html
I just did some further tinkering and it is a compiler issue.  when I change it to int return values it works…
