Can you test once by directly connecting your board to the computer running your TCP server?
Can you share the values you have configured for ipconfigNETWORK_MTU and ipconfigTCP_MSS (if defined) in the FreeRTOSIPConfig.h?
If ipconfigTCP_MSS is not defined in FreeRTOSIPConfig.h try defining it to a value less than or equal to 1400 and check.
ok, i will do it later
i defined mtu=1500, mss=1460 in FreeRTOSIPConfig.h
I tried to connect my board to computer directly, and get the same result.
net-1.zip (13.1 KB)
Did you try lowering ipconfigTCP_MSS in FreeRTOSIPConfig.h try defining it to a value less than or equal to 1400?
aha,i tried to define it to 1200, now it seems working well!!
Thanks very much!
Thanks for reporting back, as documented here: MSS - FreeRTOS™
Some setups might restrict MSS to 1400 bytes for reliability; that might be the case here. Or probably your server application might be rejecting packets above 1400.
Can you share the version of FreeRTOS+TCP you are using?
sorry for that i forget which version i use, could you tell me how to find the version i am using?
You can take a look at the History.txt or manifest.yml file in the root folder of the FreeRTOS+TCP library.
ok. The version is v4.2.0
Thanks for sharing the version.
