I am working with a single-core FreeRTOS application on an ARM Cortex-A55 using AArch64.
I traced xSemaphoreTake() → xQueueSemaphoreTake() and inspected the generated AArch64 assembly.
The mutex acquisition is performed inside a FreeRTOS critical section. In the generated assembly, I see:
MSR DAIFSet, #3
LDR
SUB
STR
MSR DAIFClr, #3
I do not see ARM exclusive instructions such as LDXR/STXR or LDAXR/STLXR in the mutex acquisition path.
I would like to confirm whether this is the expected behavior for a single-core AArch64 FreeRTOS configuration.
In particular:
- Is the critical-section approach with interrupt masking the expected way to protect the mutex state on a single-core AArch64 system?
- In which FreeRTOS configurations would ARM exclusive instructions such as LDXR/STXR normally be required?
- Are they primarily relevant to SMP/inter-core synchronization?
I am trying to understand whether the behavior I observed is expected for the single-core AArch64 FreeRTOS design.
