What is configMAX_PRIORITIES set to? If it is set to 4, then priorities 0 to 3 are valid. That means task B will get its priority capped to 3, and both tasks will have the same priority. Even then, you would expect the tasks to time slice.
Can you create very simple tasks that do nothing but increment a variable then delay? For example
I think the problem is memory, if I lower the stack (from 1024 to 256), it seems to run, but I am surprised that it didn’t complain when it failed to allocate 1024 byte stack
Unless you are using ES marked chips, please ensure to use the FreeRTOS code from the Atmel ASF (http://asf.atmel.com).
If you are using heap_1, heap_2 or heap_4.c then a failed allocation will return NULL, and if you have configASSERT() defined, the null will trigger an assert. In any case, the task won’t get created. If you are using heap_3.c then what happens is determined by the compilers C library. If the library just lets the heap run into the stack, then you will get random and very hard to debug crashes!
heap_1.c is built on the assumption that memory requested of it will never be given back, and thus can use a very simple control model. Thus a program that uses heap_1.c should never delete a task, queue, semaphore, etc.
heap_2.c is built to allow for deletion of memory, but does not defragment or merge blocks. This means that limited deleting and then recreating tasks, queues, semaphores, etc can work, but unless you are careful to be asking for the same sizes each time, you may run into memory fragmentation issues over time.
heap_3.c uses the library’s malloc and free to get memory, This can still have issues with memory fragmentation is certain extreme situations, but if a few basic conditions can be met, this can be largely minimized.
Many embedded coding guidelines prohibit or severely limit the use of dynamic memory allocations (like malloc/free) during the operation of an embedded system (it may be allowed at startup, but after that generally no critical operation should depend on dynamic memory allocation), but instead use preallocated and saved buffers, so the limitations of heap_1.c may not be as bad as it might seem. I find the biggest issue with using heap_1.c or heap_2.c is the need to explicitly declair how much memory to allocate to it vs the malloc heap and the main program stack. This is just another design point that needs to be evaluated.
To do the switch, you just need to change which file is included in your project, and to make sure that your config file defines the needed values.
That is an interesting question. This is something I do, but only because I have knowledge of the internals of FreeRTOS. The state of a task is known by the list it is referenced from, and the list it is reference from is known by looking at the generic list item in the tasks tcb. It would be good if there was an API function to do that. Can you add that to the feature request list.
For now, look at the function vTaskList(), And how the function is implemented. vTaskList returns a table that tells you, along with other things, the state that each task is in. It is in text though, so you would have to parse the table.
