I am using the FatFs from here and got a few questions. Anyone has the relevant experience?
In what scenario can f_msfs be set 0? Is it needed for a EEPROM device?
According to the description of the configuration of FF_VOLUMES and FF_STR_VOLUME_ID.
I have only one memory EEPROM. So I set FF_VOLUMES 1. And as I want to use the format 1:/, I set FF_STR_VOLUME_ID 0.
From the function f_mkfs(), the result is INVALID_DRIVE. Is it a valid combination? -
How to write the function disk_ioctl() to use the parameter cmd and buff.
In f_mkfs(), it passes sz_vol to buff. I assume the value of sz_vol is assigned in disk_ioctl() when the cmd is GET_SECTOR_SIZE.
Thanks!
Crane
